[Fwd: LABELING AREAS]
Leslie Apollon la at las.com
Wed Feb 4 13:43:46 EST 1998
This is exactly what I did with the sed command. The dig_ascii listing was
to show where the L A switches are located...
I guess I wasn't clear enough...
>Leslie,
>The problem with your grass file is that grass thinks your area are
>lines. You must edit the dig_ascii file an change the "L" to "A".
>before you import the file.
>Johnny Duke
>GIS TECH
>jduke at ar.nrcs.usda.gov
