r.in.ascii
Stephan Haverkamp
Stephan.Haverkamp at agrar.uni-giessen.de
Fri Jan 16 04:24:21 EST 1998
On Fri, 16 Jan 1998, Houxiang Wang GEO Grad 96 wrote:
> Hi dear GRASS users:
> I am having troubles importing files from idrisi, and hereby securing helps from
> you.
> I have exported idrisi files using ascii raster format. And then I edited the
> file (deleting the first two lines of projection and zone, so there are six
> lines as the header). After ftp them to GRASS, I ran r.in.ascii. Everything
> looked okay. However, when I tried to display it, it was blank--three or four
> non-sense colorful lines at the top, and elsewhere was just white. I checked the
> file under cellhd directory. It reads:
> proj: 1
> zone: 16
> north: 4386270
> south: 4351770
> east: 730110
> west: 686490
> cols: 1454
> rows: 1150
> e-w resol: 30
> n-s resol: 30
> format: 0
> compressed: 1
> Actually it is in UTM 16, and it is within the current region. I am not sure of
> the last sentence. Does it mean that the file is compressed so that GRASS could
> not process it correctly?
> I also tried to export from idrisi using binary format, which produces two
> directories--cell and cellhd, each containing one file of the same name. In
> grass I then ran r.support to get a color table for it. However, this time it
> was even worse--I couldn't get the file done.
> I am stuck. Could someone give me some hints? Thanks a lot in advance.
> Houxiang
Dear Houxiang,
I had also some problems when exchanging maps from Idrisi to Grass but now
it works. I used Idrisi for Windows 1.0 and Grass 4.1.
It is correct to delete the first two line of the Idrisi output-data-file
and to use ASCII-data-format.
I did not use UTM but Transverse Mercator and Geographic projection (proj
3 and 99). I solved my problem by changing the format of east/west and
north/south data. (Idrisi format does not fit Grass format, so errors
occured). So I would suggest check the digits of your input by g.region.
Good luck,
Stephan
Stephan Haverkamp
Institut für Landeskultur
Senckenbergstr. 3 priv.: Grabenstr. 14
D-35390 Giessen 35396 Giessen
Tel.: 0641/99 37384 Tel.: 0641/54470
Fax.: 0641/99 37389
e-mail: Stephan.Haverkamp at agrar.uni-giessen.de
