Mirror site with wget
Justin Hickey
jhickey at impact1.hpcc.nectec.or.th
Thu Jun 18 13:02:39 EDT 1998
Hello all
I set up a mirror site of Markus's http and ftp sites using wget. After
compiling wget, this is what I did:
1. Defined directories under my http server and my ftp server to hold the grass
data
2. Made changes (set proxies etc.) to the global wgetrc file (default is
/usr/local/etc/wgetrc). The only change worth noting is that I added the
following line so that the host name of the URL's would be dropped when saving
them
add_hostdir = off
Otherwise, a directory is created with the name of the host machine (eg
www.laum.uni-hannover.de) as the root of your mirror site.
3. Wrote a shell script to run the wget commands (I plan to use this script as
a cron job) shown below
------------------------------ begin script ----------------------------------
#! /bin/sh
# Rotate the logs
mv /home/webmaster/mirrorLog/httpLog3 /home/webmaster/mirrorLog/httpLog4
mv /home/webmaster/mirrorLog/httpLog2 /home/webmaster/mirrorLog/httpLog3
mv /home/webmaster/mirrorLog/httpLog1 /home/webmaster/mirrorLog/httpLog2
mv /home/webmaster/mirrorLog/httpLog0 /home/webmaster/mirrorLog/httpLog1
mv /home/webmaster/mirrorLog/ftpLog3 /home/webmaster/mirrorLog/ftpLog4
mv /home/webmaster/mirrorLog/ftpLog2 /home/webmaster/mirrorLog/ftpLog3
mv /home/webmaster/mirrorLog/ftpLog1 /home/webmaster/mirrorLog/ftpLog2
mv /home/webmaster/mirrorLog/ftpLog0 /home/webmaster/mirrorLog/ftpLog1
# Get the grass html pages
wget -b -m -np --cut-dirs=3 -P /www/grass -o /home/webmaster/mirrorLog/httpLog0
http://www.laum.uni-hannover.de/iln/grass/grass42/
# Get the grass ftp pages
wget -b -m -np --cut-dirs=2 -P /ftp/grass -o /home/webmast/mirrorLog/ftpLog0
ftp://130.75.72.14/pub/grass421/
----------------------------------- end script ------------------------------
Notes:
The above shows a rotation of 5 logs each of wget output
The wget commands should all be on one line (of course)
Explanation of the options:
-b run in the background
-m use the mirror options
-np no parent files - only download files that are under
the
given URL, even if there are links to files in other
directories (eg without -np, if there is a link to the
website's top page you will download the whole site
instead of just the grass files)
--cut-dirs=n remove n directories from the path of the URL (eg http
URL is www.laum.uni-hannover.de/iln/grass/grass42/ if n
equals 3 then iln/grass/grass42 is removed from the
URL.
Otherwise the mirror site will have iln/grass/grass42
as its root)
-P <dest> path to the mirror site destination
-o <log> specify the log file
I hope this is of help to anyone who is setting up a mirror site.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
