probleme opening monitors
Alexandre Rodier alexrod at fcu.um.es
Fri Jun 26 04:56:53 EDT 1998
Karine ZUERCHER wrote:
> Hey everybody!
> I've already got another probleme: I can't open any monitors.
> I'm working on a PC, not connected to any network and with linux installed
> just now to work with GRASS.
> Here's the message I get when trying to start the monitors (d.mon):
> name            description                    status
> x0              X-windows graphics display     not running
> x1              X-windows graphics display     not running
> x2              X-windows graphics display     not running
> x3              X-windows graphics display     not running
> x4              X-windows graphics display     not running
> x5              X-windows graphics display     not running
> x6              X-windows graphics display     not running
> CELL            Create GRASS Raster File       not running
> X Error of failed request:  BadMatch (invalid parameter attributes)
>   Major opcode of failed request:  78 (X_CreateColormap)
>   Serial number of failed request:  30
>   Current serial number in output stream:  31
> Please start graphics monitor <x0>.
> Error - Graphics monitor <x0> not running!
> Problem selecting x0. Will try once more
> Thanks a lot if you could help
> karine
> \  Karine ZUERCHER               zuercher at sc2a.unige.ch   /
> /               University of Geneva                      \
Perhaps your problems comes from the configuration of your monitor (Pc´s
monitor). GRASS works with 8 bits colormap, and if you have a monitor
with an higher resolution (16 bits, or 24 bits), GRASS  can't open his
display monitor. Try to configurate your monitor resolution with
Xconfigurator in Linux. Choose an 8 bits resolution, so open startx and
try to open one GRASS monitor display.
Try it and tell me if it works.
Alexandre Rodier
INUAMA
Universidad de Murcia
Campus de Espinardo
30100 - MURCIA -
- SPAIN -
