problems to open graphics device
Malcolm Williamson
malcolm at cast.uark.edu
Tue Mar 10 14:24:41 EST 1998
The standard GRASS xdriver only works on 8-bit graphic displays. Check
your PC display to be sure that it is set to 256 colors. If you wish to
be able to display on a PC running more than 256 colors, you'll need to
get the contributed "24XDRIVER" code off of GRASS ftp site. This will
provide you with a GRASS 8-bit display window that will work on 24-bit
desktops. Good luck,
Malcolm D. Williamson - GIS Specialist E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Phone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701 Web: http://www.cast.uark.edu
On Tue, 10 Mar 1998, sx Wu wrote:
> Hi,
> I got an error message when I tried to open GRASS monitor from a remote PC. The error
> message is:
> X Error of failed request: BadMatch (invalid parameter attributes)
> Major opcode of failed request: 78 (X_CreateColormap)
> Serial number of failed request: 227
> Current serial number in output stream: 228
> Error - Can't set up pipe to graphics device.
> Problem selecting x1. Will try once more.
> By the way, it doesn't have that problem when I run GRASS from the SUN console. I
> think I set the "xhost" correctly in my PC and I have no problem to
> link to open windows/graphics from other software remotely.
> I am a new user in using GRASS. Thank you much for your help.
> S.X. Wu
> Free web-based email, Forever, From anywhere!
> http://www.mailexcite.com
