ps.map and Linux
Richard E Nairn ren at spans.gscc.nrcan.gc.ca
Wed Mar 25 18:24:39 EST 1998
Ok, on to the next problem... I am using ps.select and ps.map.. If I
don't have a ps painter set up it will use the normal 8.5 / 11
definition. and it will turn out fine... However if I use ps.select to
select another page size and run the same script, the raster image
will come out blank...
Does anyone else have this problem??? This happens if I compile it
myself, or if I use the binary compiled version from Markus Neteler.
Richard Nairn
Geological Survey of Canada
** Email ren at spans.gscc.nrcan.gc.ca   **
**	 nairnr at cadvision.com         **
