Solaris and XGRASS 4.2.1
Clifton Wood cbwood at vt.edu
Tue May 5 15:08:46 EDT 1998
Hey again!
> So before I start examining every line with a fine tooth comb...has
> anyone gotten XGrass to work on a Sun UltraSPARC running Solaris v2.6?
> That way at least I'll have some inkling as to how serious the problem
> is.
After mucking about with the sources some more, I decided to upgrade the
installed copy of LessTIF with the one provided in the 4.2.1 release and
then recompiled the actual xgrass EXE. It runs now and pops up a window,
but when it prompts me for a database, I only see the first part, (the
path where the locations are stored - GISBASE) I don't see any
of our installed locations or mapsets. How do I set this up under
XGrass? Or is there still something wrong with the executable that's
preventing these choices from appearing?
Thanks.
							- Cliff
Clifton B. Wood
Programmer/Analyst for Virginia Tech's AGNIS Department
-------------------- Thought of the Day --------------------
windows95 = n.  32 bit extensions and a graphical shell for
a 16 bit patch to an 8 bit operating system originally coded
for a 4 bit microprocessor, written by a 2 bit company that
can't stand 1 bit of competition.
