Problem running GRASS / Deleting Characters
Skip Haak
shaak at teleport.com
Thu May 14 10:42:37 EDT 1998
Anthony,
Solved my problem, I couldn't write to my home directory. Changed
permissions and then everything worked fine. Thanks a bunch for your help.
I have another question. If I make a mistake entering location, mapset,
etc., the program doesn't let me use the backspace or delete keys to edit
the text. I haven't been able to find anything that says whether there is a
solution to this problem or I just have to live with it. Is there some way
to solve this problem?
Thanks, Skip
>Skip
>This message will probably be more helpful than the first.
>The other issue is that the .gislock file is created in your home directory
>when you start up grass. Something is odd, but are the owner and permission
>okay in your $HOME directory that will allow grass to create the .gislock
file.
> If you are not running GRASS and a .gislock file exist remove it as a new will
>be created when you start GRASS. Again you have to be able to write to it.
>Good Luck
>If you have any questions you can respond directly to me at:
>agburns at kcc.fsa.usda.gov
>Anthony Burns
Skip Haak
Applied Ecosystem Services, Inc.
950 Lloyd Center, Suite 48
Portland, OR 97232
(503) 460-3198
(503) 460-3230 Fax
shaak at appl-ecosys.com
