printing on network printer
Michel Wurtz - LTE mw at engees.u-strasbg.fr
Thu Nov 5 02:57:36 EST 1998
Francisco Estrada Belli wrote:
> Dear Grass experts,
> I wonder if someone could tell me how to set up a printer that is not
> attached
> to a machine through a tty device but has it's own ip address and prints
> with
> the lpr program.  I would like to be able to use it for output with
I print all through a HP Laser postscript printer on our local
Ethernet network.  What I have done :
1- set up the printer (give him an IP address, +etc)
2- give a name to the printer (hplaser here) in the DNS server
   (or in /etc/hosts if you want to print even when your DNS server
   goes down :-()
3- update /etc/printcap and restart the lpd daemon.  Here is the
   content of mine. look at the manual (printcap, section 5) for
   options detail and customizing (you need perhaps other settings)
lp|postscript:\
        :lp=:rm=hplaser:sd=/usr/spool/lp:sh:mx#0:\
        :af=/usr/adm/lp-acct:lf=/usr/adm/lpd-errs:
Hope this can help you,
Michel Wurtz    ENGEES - Laboratoire Territoires & Environnement
                1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
                Tel: +33 03.88.24.82.45  Fax: +33 03.88.37.04.97
