Basic NMEA Sentence formats (was: GPS input and GRASS)
Clifton Wood cbwood at vt.edu
Tue Oct 6 18:52:44 EDT 1998
Jill and Venkatesh:
The NMEA 0183 data format varies from GPS unit to GPS unit since most
manufacturers like to insert their own proprietary extensions to the
format, but here are a few of the standard message sentences which
should be available on most units that claim NMEA complaince:
"<>" denotes Carriage Return & Line-Feed pair.
__GGA = Global Positioning Fix Data
__GGA,hhmmss.ss,ddmm.mmmm,n,dddmm.mmmm,e,q,ss,y.y,a.a,z,g.g,z,t.t,iiii*CC<>
		hhmmss.ss = UTC of position fix
			hh = hours (00-24)
			mm = minutes (00-59)
			ss.ss = seconds (00.00-59.99)
		ddmm.mmmm,n = latitude
			dd = degrees (00-90)
			mm.mmmm = minutes (00.0000-59.9999)
			n = direction - N - North; S - South
		dddmm.mmmm,E = longitude
			ddd - degrees (000-180)
			mm.mmmm - minutes (00.0000-59.9999)
			e = direction - E - East; W - West
		q = GPS quality indicator
			0 - GPS not available
			1 - GPS available
			2 - GPS differential fix
		ss = number of satellites used (0-12)
		y.y = HDOP
		a.a,z = antenna height
			a.a = height
			z = units	M - Meters
		g.g,z = Geodial Separation
			g.g = height
			z - units	M - Meters
		t.t = Age of differential data
		iiii = differential ref. station ID (0000-1023)
		CC = checksum (hex 00-7F)
__CSA = Geographic Position - GPS DOP and Active sattelites
	__GSA,a,b,cc,dd,ee,ff,gg,hh,ii,jj,kk,mm,nn,oo,p.p,q.q,r.r*CC<>
		a - sat acquisition mode	M - Manual
						A - Automatic
		b - pos mode			1 = fix not avail
						2 = 2D
						3 = 3D
		cc,dd,ee,ff,gg,hh,ii,jj,kk,mm,nn,oo	sat ids used in solution
							(null for unused fields)
		p.p = PDOP	(1.0-9.9)
		q.q = HDOP	"
		r.r = VDOP	"
__RMC = Recommended Minimum Specific GPS
	__RMC,hhmmss.ss,a,ddmm.mmmm,n,dddmm.mmmm,w,z.z,y.y,ddmmyy,d.d,v*CC<>
		hhmmss.ss = UTC of position fix (see GGA)
		a = status	A - valid
				i -  invalid
		ddmm.mmmm,n - Latitude (see GGA)
		dddmm.mmmm,e - Longitude (see GGA)
		z.z = Speed over ground (knots)
		y.y = track made good	(0.0-359.9; reference to true north)
		ddmmyy = UTC date of position fix
			dd = day (01-31)
			mm = month (01-12)
			yy = year (00-99)
		d.d = magnetic variation (0.0-180.0; degrees)
		v = variation sense	E - East
					W - West
__GSV = GPS Satellites in View
	__GSV,t,m,n,ii,ee,aaa,ss,ii,ee,aaa,ss,ii,ee,aaa,ss,ii,ee,aaa,ss*CC<>
		t = Total number of messages (1-3)
		m = message number (1-3)
		n = total number of satellites in view
	For each visible satellite, 4 groups per message
		ii = satellite PRN number
		ee = elevation (0-90; degrees)
		aaa = asimuth (0-359; degrees true)
		ss = signal to noise ratio (0-99; dB)
Not all GPS units that claim NMEA compliance will support ALL of these
formats except
for GGA (which is universal, I think...)
Good luck!
- Cliff
PS - I don't know how up to date this is, but since I can't find info on
the format fro NMEA's own pages (http://www.nmea.org/), this is the best
I can do for the moment.
Clifton B. Wood
Programmer/Analyst for the Entomology Dept. of Va. Tech.
------------------ Thought of the Decade -------------------
windows98 = n. 64 patches to 32 bit extensions and a graphical
shell for a 16 bit patch to an 8 bit operating system originally
coded for a 4 bit microprocessor, written by a 2 bit company
that can't stand 1 bit of competition.
