About GPS input and GRASS
Venkatesh Raghavan
raghavan at media.osaka-cu.ac.jp
Tue Oct 6 22:44:52 EDT 1998
Most of the GPS manufacturers these days claim NMEA (National
Marine Electronics Association) format support.
I would like to interface a GPS via RS232Cserial
port and possibly the s.in.gps function to get the data into GRASS.
Since NMEA seems to be the standard format, I was wondering
if I could use s.in.gps to directly read the NMEA file.
Clifton Wood has given details about the NMEA format and
Peter Bennett's home page gives additional details of NMEA format and
also lists some software tools.
The URL is http://vancouver-webpages.com/pub/peter/index.html
If it would possible to have some thing like s.in.gps.nmea in GRASS
it would be very useful to me.
Thanks
Venkatesh Raghavan
Osaka City University
An example of the NMEA output is shown below
Example: $GPGGA,170834,4124.8963,N,08151.6838,W,1,05,1.5,280.2,M,-34.0,M,
,*75
Name Example Data
Description
Sentence Identifier $GPGGA Global
Positioning
System Fix Data 170834
17:08:34 Z
Time
Latitude 4124.8963, N
41d 24.8963' N or 41d 24' 54" N
Longitude 08151.6838, W 81d
51.6838' W or 81d 51' 41" W
Fix Quality: 1
Data is from a GPS fix
- 0 = Invalid
- 1 = GPS fix
- 2 = DGPS fix
Number of Satellites 05 5
Satellites are in view
Horizontal Dilution of Precision (HDOP) 1.5 Relative
accuracy of
horizontal position
Altitude 280.2, M
280.2 meters above
mean sea level
Height of geoid above WGS84 ellipsoid -34.0, M -34.0 meters
Time since last DGPS update blank No last
update
Checksum *75
Used by program to
check for transmission
errors
Jill Schuler wrote:
> Venkatesh,
> I'm not sure what the NMEA format is, but s.in.gps works with a comma
> delimited file. The file format has 5 fields. The script extracts
> the fifth field from the 2 to 15 character. This information is then
> processed with s.in.ascii.
> I also have a new version of the command that works with PLGR gps units:
> s.in.gps2.
> If you provide me with the format, I will modify the s.in.gps command
> to fit your format.
> Jill
