Point Importing
Malcolm Williamson
malcolm at cast.uark.edu
Mon Oct 19 22:08:57 EDT 1998
Hi, Taravudh
As these points really represent vertices of a polygon, rather than
sites, the ASCII file needs to be imported using v.in.ascii. Check the
manual pages for format specifics; I recommend using v.out.ascii on an
existing vector file so that you can see the expected file format.
I don't have GRASS handy at the moment, and I don't recall the header
format, but the basic structure for the coordinate part is as follows:
(let's assume there are 8 coordinates)
A 9
x-coordinate1 y-coordinate1
x-coordinate2 y-coordinate2
x-coordinate3 y-coordinate3
x-coordinate4 y-coordinate4
x-coordinate5 y-coordinate5
x-coordinate6 y-coordinate6
x-coordinate7 y-coordinate7
x-coordinate8 y-coordinate8
Note that the first and last coordinate pair are the same. Also, I may
have my x- and y-coordinates reversed; please check the manual. After
importing this file with v.in.ascii, you'll need to run v.support. After
that, you can label the polygon in v.digit if desired.
Regards,
-Malcolm Williamson
On Tue, 20 Oct 1998, taravudh wrote:
> Hi All,
> How to combine sites that were converted from ascii files by using
> s.in.ascii ? The ascii files received from GPS data that I used it to
> locate flood boundary. The example below is details.
> x
> x x
> x x
> x x
> x x
> x x
> x x
> x
> Anyway, I'd like to know how to combine them after I used s.in ascii.
> Thank you very much
> Taravudh..
