Conversion of lat-Lon rasters to UTM
Bruce Nielsen
bnielsen at in.nrcs.usda.gov
Thu Sep 17 09:14:26 EDT 1998
Terry Duell wrote:
> Ladies and Gentlemen,
> I hope someone can help me.
> I have some raster (cell) data files in a lat-lon projection, and would
> like to extract relevant sections and convert to UTM and save into an
> appropriate UTM mapset.
> The problem is that I can't remember how to do this (or even if I have
> been able to do so in the past...age has its difficulties!), nor can I
> find any GRASS commands which seem to fit the bill.
> Any help or advice will be gratefully appreciated.
> Cheers,
> Terry Duell, Senior Mobility Engineer
> Army Technology & Engineering Agency
> Maribyrnong, Victoria, Australia
> ph:61-3-93195837 fax:61-3-93195830
The only method I can think of is to convert the raster to a vector
using r.poly, then use v.proj to do the projection converstion to UTM.
Before using v.proj, however, be sure you have a DATUM_INFO file in the
PERMANENT mapsets of both locations. Here's the contents of DATUM_INFO
for the clarke66 spheroid in the continental US:
datum: nad27
region: conus
You will have to change these values appropriately. Then convert your
vector back to raster using v.to.rast.
Method 2: I remember some talk about a command r.proj a couple years
ago, but I don't know if it was ever done. I believe Dr. Simon Cox,
also from Australia, was working on it. Any other old-timers remember
this?
