Conversion of lat-Lon rasters to UTM
Malcolm Williamson
malcolm at cast.uark.edu
Thu Sep 17 10:32:04 EDT 1998
On Thu, 17 Sep 1998, Bruce Nielsen wrote:
(lines deleted)
> Method 2: I remember some talk about a command r.proj a couple years
> ago, but I don't know if it was ever done. I believe Dr. Simon Cox,
> also from Australia, was working on it. Any other old-timers remember
> this?
Simon wrote a shell script called r.proj, which I will be glad to pass
along in its 1997 flavor. Below is a brief description of it. I also
checked the ftp site on the moon (moon.cecer.army.mil) and found a
different r.proj, written by Martin Schroeder of the University of
Heidelberg, which claims to work under floating-point GRASS only.
Please note Simon's disclaimer regarding _large_ ascii intermediate
files! Make sure that you consider the consequences of going from a
run-length encoded binary file to an uncompressed ascii file. Also note
that you must have s.sample on your system.
Regards,
-Malcolm Williamson
# r.proj
# copies a cell-map from one GRASS location to another
# using the PROJ_INFO parameters to re-project the map
# and the current region settings to determine the location, size and
resolut
ion
# The user must have write permissions in a couple of places
# r.proj is a script: it uses
# Gerry Evenden's PROJ program to convert the target cell-locations
to
# the source projection
# Darrell McCauley's s.sample program to resample the source map at
the
# target cell-locations;
# defaults to nearest-neighbour resampling
# (appropriate for "category" maps)
# but can also use bilinear or cubic interpolation
# (appropriate for "continuous" maps)
# Only tested for a limited range of projections.
# The intermediate file is ascii so can be very large.
# The s.sample stage takes a while (!) if the map is large.
