tcltkgrass error
Markus Neteler
neteler at geog.uni-hannover.de
Fri Sep 25 09:15:46 EDT 1998
Hi Steve,
> I am attempting to get tcltkgrass2.3 to run under SuSE 5.3 Linux. I
> installed Grass 4.2.1 and it runs correctly. I then installed the Linux
> version of TclTK8.0 following the instructions (although I originally
> extracted the package in /tmp instead of /). I then installed TCLTKGRASS
> 2.3 following the instructions.
> However, when I run tcltkgrass, I get the following error message:
> loading...
> wish8.0: can't load library
> 'libtk8.0.so'
.. as written there: You did not install the TK 8.0 libraries... :)
Just get them from the Linux Binary page of the 4.2.1-WWW-Server.
If it is already installed, please check the file location. It should
be in /lib.
Best wishes
Markus
(PS: I am using the same Suse 5.3 ...)
