tcltkgrass error
Steve Watts watts.67 at osu.edu
Fri Sep 25 07:31:10 EDT 1998
At 09:15 AM 9/25/98 +0100, you wrote:
>Hi Steve,
>> I am attempting to get tcltkgrass2.3 to run under SuSE 5.3 Linux.  I
>> installed Grass 4.2.1 and it runs correctly.  I then installed the Linux
>> version of TclTK8.0 following the instructions (although I originally
>> extracted the package in /tmp instead of /).  I then installed TCLTKGRASS
>> 2.3 following the instructions.
>> However, when I run tcltkgrass, I get the following error message:
>> loading...
>> wish8.0: can't load library
>> 'libtk8.0.so'
>.. as written there: You did not install the TK 8.0 libraries... :)
>Just get them from the Linux Binary page of the 4.2.1-WWW-Server.
>If it is already installed, please check the file location. It should
>be in /lib.
>Best wishes
>  Markus
>(PS: I am using the same Suse 5.3 ...)
Thanks for the reply!
Here is what I did wrong.  I extracted the TK 8.0 libraries in /tmp as I
stated in my first post.  Then I installed tcltkgrass2.3.  Then I realized
that TK 8.0 had installed in the wrong place since it was extracted in /tmp
instead of /, so I deleted the files in /tmp and extracted it in /.  At
this point tcltkgrass did not work.  After sending my previous post and
thinking about it for awhile, I decided to delete tcltkgrass and then
reinstall.  It now works correctly, so it appears that TK 8.0 must be
installed *correctly* before installing tcltkgrass.  Of course if I really
knew what I was doing ;) I'm sure I could have just moved the files and
changed some links to get it to work correctly without going through the
delete and reinstall process.
Now, I just need to figure out what file permissions need to be changed so
I can use it in a non-root account.
Regards,
-Steve
