s.in.asci - Porblem ?
Phisan Santitamnont
fsvpss at eng.chula.ac.th
Thu Apr 1 21:20:01 EST 1999
Hi Michael,
Michael Schulz wrote:
> Hi !
> Obviously, we are experiencing some problems when trying to import a ASCII
> XYZ-file into GRASS-Site-file (with GRASS 5).
> The ASCII-file has the format:
> easting northing #z-value (field sep: space)
> After running s.in.ascii (with dimensions = 3 ) we get the following
> format of the SITE-file:
> easting|northing|0
> When we import the ASCII-file without the '#' in front of the z-value,
> s.in.ascii reads the third row (but then it does not use the thrid row as
> a category value).
you'd try ./src.alpha/sites/s.in.ascii.dem coming with
GRASS 4.2.1. It reads plain vanilla X Y Z.
Regards,
Phisan Santitamnont, Dr.-Ing.
Survey Engineering Department
Chulalongkorn University
Pathumwan Rd, Bangkok 10330
Tel. +66 (2) 218 66 61
Fax. +66 (2) 218 66 53
mailto:fsvpss at eng.chula.ac.th
http://www.sv.eng.chula.ac.th/Staff/Phisan
