Hi, I wonder if there are a tool to digitize contour lines without the straight line type that uses v.digit. Or within it, do I can manage to contour irregular shapes? One more think, when running on Tcltkgrass env., every time I click on v.digit, the X monitor minimizes and viceversa. Is there any way to avoid this irksome feature. Thanks a lot Antonio Rodríguez V.
