GISGEN failure at STEP: src/raster/r.binfer
Jeff Hamann hamannj at ucs.orst.edu
Wed Apr 21 20:36:28 EDT 1999
I discovered that I don't have all the binaries compiled when I
tried to use the r.report command......
So after trying to "re"compile GRASS on Linux and run into the following......
[root at ren CMD]# GISGEN.my
GISBASE=/usr/local/grass42
SRC=/usr/local/grass42/src421/src
CMD=/usr/local/grass42/src421/src/CMD
HEADER=linux
ARCH=linux
GISGEN                              Wed Apr 21 17:35:57 PDT 1999
 GISBASE = /usr/local/grass42
 SRC     = /usr/local/grass42/src421/src
 CMD     = /usr/local/grass42/src421/src/CMD
 HEADER  = linux
 ARCH    = linux
first step: src/raster/r.binfer
GISGEN: src/raster/r.binfer - Wed Apr 21 17:35:57 PDT 1999
/usr/local/grass42/src421/src/raster/r.binfer
  make -f OBJ.linux/make.rules
rm -f lex.c gram.c
yacc binfer.y
rm -f gram.c
mv y.tab.c gram.c
rm -f OBJ.linux/gram.o
gcc -O2 -m486 -fwritable-strings  -DATT_386  -I/usr/local/grass42/src421/src/inc
lude   -DUSE_TERMIO -c gram.c
mv gram.o OBJ.linux/gram.o
lex -l binfer.l
make: lex: Command not found
make: *** [lex.c] Error 127
[root at ren CMD]#
is this a makefile problem? there is still plenty of hard disk space and I
thought that someone else recently posted this problem.
What don't I have set up correctly?
Thanks,
Jeff.
Jeff D. Hamann
277 SE Lilly
Suite H
Corvallis, Oregon 97333 USA
541-754-3309
http://ucs.orst.edu/~hamannj
