GISGEN failure at STEP: src/raster/r.binfer
Michel Wurtz - LTE
mw at engees.u-strasbg.fr
Thu Apr 22 02:38:18 EDT 1999
Jeff Hamann wrote:
> I discovered that I don't have all the binaries compiled when I
> tried to use the r.report command......
> So after trying to "re"compile GRASS on Linux and run into the following......
> make: lex: Command not found
Maybe you didn't have "lex" installed. On some versions it is
called flex (GNU version of the lexical analyser). To see if
you have lex or flex :
bash$ which lex
/usr/bin/lex
bash$ which flex
/usr/bin/flex
bash$ ll /usr/bin/*lex
-rwxr-xr-x 1 root bin 130620 Feb 6 1997 /usr/bin/flex*
-rwxr-xr-x 1 root bin 21 Jan 17 1995 /usr/bin/lex*
if you have flex but not lex, lex is just a shell script saying
flex -l $*
If you haven't either, look at your Linux distribution. You have to
install the package (you will also probably need yacc for compiling
some modules of Grass)
Hope this helps
Michel Wurtz ENGEES - Laboratoire Territoires & Environnement
1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
