We can't import more than 49 files
Luis F. Franco
luis.franco at icp.pt
Thu Apr 22 13:48:49 EDT 1999
Hi
I have a script that combines a unspecified number of maps using r.combine.
It has an intermediate step that combines the files in groups of 10 and then
executes r.combine, and then combining the groups in groups of 10 again,
running r.combine, etc... until the
It can easily be modified to run r.patch instead of r.combine (I think...).
If someone wants it I can pass it to the group. I uses awk as it main tool.
Luís Franco
Instituto das Comunicações de Portugal
Email- luis.franco at icp.pt
-----Original Message-----
From: Utente Grass [mailto:grass at meteux.ismaa.it]
Sent: Thursday, April 22, 1999 11:18 AM
To: grass at cecer.army.mil
Subject: Re: We can't import more than 49 files
On mer, 21 apr 1999, you wrote:
> As far as I know GRASS has not realistic limit for the number of mapsets
> that are allowed. I have created directories with hundreds of maps with
> no problem. Instead could this be a disk space related error you are
having?
> R. Joe
> On Wed, 21 Apr 1999, Utente Grass wrote:
> > S.Michele 21.IV. 99 Italy
> > We are only beginers; we created a little program to import
automatically 215
> > files ascii in GRASS. It works only for 49 files then GRASS prints a
errore
> > message! Why?
> > Do you know if a mapset can accept only 50 files ? Does the mapset have
a
> > dimension limit ?
> > Help us!!
> > Thank you
> R. Joe Brandon
> Center for Advanced Spatial Technologies (fax) 501 575-5218
> Rm. 12 Ozark Hall 501 575-4277
> University of Arkansas rjoe at cast.uark.edu
> Fayetteville, AR 72701
> Updated! -> http://www.cast.uark.edu/~rjoe
> Computers are actually powered by Chaos theory, not electricity...that
> is just for the fan. (T. Hesser)
S.Michele 22.IV.99 Italy
Thank you for your message. The real problem was format errors in ascii
data.
We've resolve them and we 're able to import 215 files.
Now we are trying to patch them all together but r.patch allows only 10
files in
input. It is possible to change the source without create new problems?
Good bye
Valentina & Marco
