d.mon problems
Michel Wurtz - LTE
mw at engees.u-strasbg.fr
Fri Apr 23 02:52:26 EDT 1999
Karin Mayer wrote:
> After installing GRASS4.x.x binaries on LINUX, I got some problems to open
> monitors with d.mon x0, for instance. I got only the sparse message:
> Problem selecting x0 Will try once more.
> It is not the "8 bit mode - XDRIVER - problem! Is there anybody out there
> who has an idea what kind of problem this might be? Thanks a lot.
It is probably a permission or missing directory problem.
Look in $GISBASE/locks directory ($GISBASE is the directory where
grass is installed). You should have a directory named after the
machine name (uname -n will give this name). This directory
*must* exist and have world rwx permission (chmod a+rwx ...).
It will contain files named mon.xxxxx where xxxxx is a number.
This file is a lock for XDRIVER. You cannot launch it if you
can't create this lock file.
Michel Wurtz ENGEES - Laboratoire Territoires & Environnement
1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
