tcltkgrass errors
    arch. Stefano Maffulli
    stefano.maffulli at DPMPE.UNIFI.IT
    Mon Aug 16 05:04:50 EDT 1999
Hi again
I double checked and I discovered that only changing the write
permission to /tcltkgrass doesn't help: I am only able to run tcltkgrass
interface if I login as root!   If I login as another user it starts
drawing a window, then it stops and gives the error:
Mapset <stef> in Location <leics>
GRASS-GRID > Error in startup script: couldn't create error file for
command: no such file or directory
    while executing
"exec xwininfo -id [winfo id .w_g] | grep -i Corners"
    (file "/usr/local/grass42/tcltkgrass/main/gui.tcl" line 1511)
    invoked from within
"source $env(TCLTKGRASSBASE)/main/gui.tcl"
    (file "/usr/local/grass42/bin/tcltkgrass" line 17)
I checked the permission for /tmp and it seems ok: owner+group+other has
rwx permissions.  Also the program xwininfo works if invoked.
What else can it be?
thank you
stefano maffulli
Markus Neteler wrote:
> Hi Stefano,
> well, your error is surprising as tcltkgrass does not
> need write permissions to that directory. Perhaps you
> check /tmp.
> > permission problem.  I don't know if it is safe (I am not a unix guru)
> > to run tcltkgrass with permission to write for all users in the
> > tcltkgrass dir.
> No idea, but if the other users won't delete it, it might not
> be a big problem.
> Best regards
>  Markus
