non-interactive start
Andrew E Long aelon at sph.umich.edu
Mon Dec 13 15:00:40 EST 1999
Hi Karin,
	I see that Michel answered your question, but I thought that I'd
attach my "batch-grass" shell script. I think that you'll only need to
change one line in this file:
GISBASE=/data/grass/ftp/src421
to whatever your GISBASE is.
	Hope this helps. Get back with any questions.
Andy
On Wed, 24 Nov 1999, Karin Mayer wrote:
> hallo GRASS community
> Is there a possibility to start GRASS with existing loacations and
> mapsets non-interactivly by shell-scripts?
> Thanks for giving some ideas.
> Karin
#!/bin/sh
#ael, Mon Nov 16 08:54:15 EST 1998
if test $# -eq 0
then
    cat <<EOF
			    batch-grass usage:
    batch-grass runs a command (or executes all commands in a file) in the
grass environment. It simply sets some environmental variables and executes
the commands.
	batch-grass location_name mapset command
	batch-grass location_name mapset -file filename
e.g.,
	batch-grass usgs PERMANENT -file make-quads
EOF
	exit 0
fi
GISDBASE=$GISBASE/data
ETC=$GISBASE/etc;
PATH=$GISBASE/bin:$GISBASE/scripts:$GISBASE/garden/bin:$PATH:/usr/bin
GISRC=/data/tmp/.grassrc.$$
cat << EOF > $GISRC
GISDBASE: $GISDBASE
LOCATION_NAME: $1
MAPSET: $2
PAINTER: ppm
MAPLP: stuff.ppm
EOF
export GISBASE GISDBASE ETC PATH GISRC
if test "$3" = "-file"
then
    cat $4 | sh
else
    # strip off the location and mapset,
    shift 2
    # then execute the command which remains:
fi
/bin/rm -f $GISRC
exit 1
