reclassification
Radim Blazek Radim.Blazek at dhv.cz
Tue Dec 14 05:51:32 EST 1999
Try  r.gdbase:
r.gdbase input=in output=out database=db rules=rec analysis=reclass
you must create dbase file 'MAPSET/dbase/db'(text) and reclass file 'rec' first
(easy)
Radim
Antonio Rodríguez Verdugo wrote:
> Hi all,
> I have some problems trying to reclassify some Arc/Info original data. I
> have the following:
> - 10 vegetation types (4, 6, 10, 15, 27, 33, 34, 41, 42, 50)
> - 11827 areas
> The areas are classified as categories and the veg types are classified as
> descriptions.
> I want to reclassify the map in function of the veg types instead of areas,
> but running r.reclass non-interactively I can't accomplish this. And with
> the interactive mode is a little crazy (11827!).
> Some ideas?
> Thanks a lot
> Antonio
> Paraje Natural Marismas del Odiel
> Centro de Calatilla
> Huelva, Spain
> rod.chav at hsoft.es
