Compiling Grass 5.0
Michel Wurtz - LTE mw at engees.u-strasbg.fr
Wed Feb 10 03:41:21 EST 1999
Michel Wurtz    ENGEES - Laboratoire Territoires & Environnement
                1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
                Tel: +33 03.88.24.82.45  Fax: +33 03.88.37.04.97
I just finished to compile grass5.0 on linux.  Here are some remarks
about the process...
All references are made relative to the main dir of installation
(grass5.0beta).
INSTALL (in . and in src/CMD) refers to "GISGEN", but the program
has the name "COMPILE".
GISGEN fails in src/mapdev/v.digspline because an error in
src/mapdev/v.digspline/Gmakefile, line 224 :
        if [ ! -d $(TXT)/DIGIT ]; mkdir $(TXT)/DIGIT; fi
should be
        if [ ! -d $(TXT)/DIGIT ]; then mkdir $(TXT)/DIGIT; fi
same error line 231 ("then" is missing)
the directory "CVS" in src/mapdev/v.digspline/digitizers must also
be suppressed if you don't want COMPILE to stop here...
INSTALL doc doesn't remind you to go to src/display/devices/XDRIVER
and run /..../grass5.0beta/src/CMD/gmake5.0 (absolute path mandatory)
After that, you can launch grass5.0, and it worked...
configuring, compiling and editing the whole thing (src/CMD/lists/GRASS
only + tkgrass, but no XGRASS) take me approximatively 1 hours 1/4
on a Pentium (Winchip) 225 Mhz, 32 Mo ram, while listening
KPIG on realaudio (mono only, on an old 8bits erzats of Soundblaster;
does anybody have a soundblaster 64 to give :-)))
