put up SG3d on linux
Terry Duell
duell at atea.mat.army.defence.gov.au
Tue Jan 5 20:47:20 EST 1999
Mark Mauerwerk wrote:
> Hi,
> we plan to put up the SG3d tool on a linux machine. Did somebody already
> made an attempt (if successful or not) to do this or has any other
> experience with the compilation of this tool?
> Thanks in advance for any hint.
You might have some trouble...it relies on the Iris GL, not OpenGL (ie
the SGI Graphics Library). Whilst there are OpenGL libs for other SGI
systems I am not aware of a compatible GL for other than SGI systems.
If you are planning to actually port the SG3d (using OpenGL or similar
lib, rather simply attempt to compile under Linux) that would be a good
thing as it is a very good tool.
Cheers,
Terry Duell, Senior Mobility Engineer
Army Technology & Engineering Agency
Maribyrnong, Victoria, Australia
ph:61-3-93195837 fax:61-3-93195830
