GRASS>How to undelete vector lines?
Malcolm Williamson
malcolm at cast.uark.edu
Fri Jan 22 18:39:47 EST 1999
This takes care of _half_ the problem, the attributes. To recover the
actual geometry, you must run v.out.ascii to produce an ASCII version of
the file. Edit the file the same way that Brian notes below, i.e., change
lower case "a" and "l" to upper case. Use v.in.ascii to re-import the
file. Run v.support when you are finished. Note that this restores _all_
deleted features.
-Malcolm
On Fri, 22 Jan 1999, Brian Culpepper wrote:
> Markus,
> To undelete lines (or areas) that have been deleted but NOT
> v.clean(ed), do the following:
> cd $LOCATION/dig_att
> vi TheVectorFile.InQuestion
> (replace all of the lower case characters (either a's or l's) along
> the left margin with the UPPER case equivalent... (eg. A or L).. The
> global replace option in VI works great for this...
> If memory serves me thats all you need to do..... ;)
> Have a good day,
> brian culpepper
> CAST
> On Fri, 22 Jan 1999, Markus Neteler wrote:
> > Hi all,
> > when deleting vectors in v.digit, they are just marked as deleted
> > (following the v.clean manual entry). v.clean would throw them
> > away later. But if I decide that I need them back, how to *undelete*
> > the vector lines? I could not find such an entry in v.digit etc.
> > Thank you
> > Markus Neteler
> R. Brian Culpepper GIS Specialist
> Center for Advanced Spatial Technologies (fax) 501 575-5218
> Rm. 12 Ozark Hall 501 575-6159
> University of Arkansas brian at cast.uark.edu
> Fayetteville, AR 72701 Home Page: http://www.cast.uark.edu
