Using GRASS commands form unix prompt
Justin Hickey
jhickey at impact1.hpcc.nectec.or.th
Wed Jan 27 03:50:31 EST 1999
Hello Venkatesh
On Jan 26, 10:57am, Venkatesh Raghavan wrote:
> Is there a way of setting up GRASS so that I can use the GRASS commands
> directly from the UNIX prompt. I faintly recall that there was some
> suggestion for doing this sometime on this ML but I am unable to locate the
> answer now.
Why can't you use the standard grass commnad line interface (running
grass4.2.1)? When you run this command it provides you with a unix shell
capable of running any unix command. The only difference between this shell and
a regular unix shell is that there are GRASS environment variables set that
allow the grass commands to run.
Is there another problem you are having?
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
