Using GRASS commands form unix prompt
Agustin Lobo
alobo at ija.csic.es
Wed Jan 27 06:45:38 EST 1999
I do not see the problem. I used to write quite a number of scripts
(csh) including some simulations of landscape change. The only thing
you must do is to start grass before runing the script. If the
script takes a long time, you can even use nohup and logout. What
you cannot do is to start grass again with different setings while
the script is runing.
If what you want is to call grass routines from within a program,
you just need to use the objects. Or take the sources, modify and
compile again. You got all posibilities, cannot be more open!
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
http://pangea.ija.csic.es/alobo
On Wed, 27 Jan 1999, Conn Copas wrote:
> "Justin Hickey" <jhickey at impact1.hpcc.nectec.or.th> writes:
> > > Is there a way of setting up GRASS so that I can use the GRASS commands
> > > directly from the UNIX prompt. I faintly recall that there was some
> > > suggestion for doing this sometime on this ML but I am unable to locate the
> > > answer now.
> > Why can't you use the standard grass commnad line interface (running
> > grass4.2.1)?
> Possibly because it is desired to issue Grass calls from within a program,
> rather than interactively. There has been previous discussion on setting
> environment vars so that these calls may be issued, but parsing the output
> remains as a sometimes tricky problem.
