Exact position of nodes in vector files
Agustin Lobo
alobo at ija.csic.es
Wed Jul 7 09:05:31 EDT 1999
I've (succesfuly) imported an arc info vector
file in geographic (lat,lon) coordinates using v.in.arc
Then I have transformed the ascii vector file from the
original geographic coordinates to Goode-Homolosine
coordinates using a non-Grass program.
Once I import the new ascii vector using v.in.ascii,
there is one single error: one node is very far away
from the region. This is probably due to some wrong
character written by the program doing the transformation.
I would need to identify the EXACT coordinates of this
node, then I would be able to search for it in the
ascii vector file, correct it and run v.in.ascii
again.
Nevertheless, I've tried both v.what and v.digspline
(i'm using grass5.0beta), and I've identified that this
wrong node is node 23 on line 23, but cannot get the
coordinates: I get cursor coordinates, but
not the coordinates of the node.
Is there any way I could identify the EXACT coordinates
of any given node?
Thanks
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
http://pangea.ija.csic.es/alobo
