error while compiling mapgen
Juergen uzs8jz at uni-bonn.de
Thu Jul 15 03:42:06 EDT 1999
I have downloaded the grass 4.2.1. and the mapgen source code from the
web pages of the Uni-Hannover. After compiling grass with only a few
errors :-) I have tried to compile the sources of mapgen. This failed
with the following error message (and a few others before which I have
already fixed). I use SUSE-LINUX 6.1 with gcc 2.7.2.3
Do you know anything about this?  Any ideas?
Thanks in advance.
	Juergen Rogozia
if test ! -d /usr/local/grass42/mapgen/etc; then mkdir
/etc; fi
#./setup_map /usr/local/grass42/mapgen
cpio: etc: truncating inode number
etc
cpio: : unknown file type
3730 blocks
cpio: premature end of file
Sys errno: 2: No such file or directory
input control file
program abnomally terminated
input control file
input control file
input control file
/usr/local/grass42/mapgen/etc/lines/misc/neatline:
/lines/misc/neatline: No such file or directory
/usr/local/grass42/mapgen/etc/lines/misc/text:
es/misc/text: No such file or directory
/usr/local/grass42/mapgen/etc/lines/misc/text2:
nes/misc/text2: No such file or directory
make[2]: *** [/usr/local/grass42/mapgen/interface/etc] Error 127
make[2]: Leaving directory
`/usr/local/grass42/src421/src.related/mapgen_6.25/nr
cs/misc'
make[1]: *** [all] Error 2
make[1]: Leaving directory
cs'
make: *** [all] Error 2
