Graphics Monitor Problem
James Curry jcurry at llnl.gov
Tue Jul 20 13:57:35 EDT 1999
Andrew M Mcdermott wrote:
> Did you create a monitorcap file, and did your setup create the nodes for
> fifo.1a etc in the correct directory? I got errors like this when I failed
> to do these two things from a source install under Linux.
Yes, I have a monitorcap file and the fifo.1a and others are in the gbase/dev
directory.
The error seems to indicate some kind of color map problem.
jcurry at llnl.gov    | James Curry
925.423.1106 voice | Lawrence Livermore National Laboratory
925.423.6775 fax   | P.O Box 808, MS:L-183
                   | Livermore, California  94550
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/19990720/0ddb2f34/attachment.html
