Graphics Monitor Problem
Andrew M Mcdermott
mcdermam at potsdam.edu
Tue Jul 20 13:34:20 EDT 1999
At 10:07 AM 7/20/99 -0700, you wrote:
> Hi,
>I just downloaded and installed the grass binary for Solaris on my
>Sparc 5 and get the following error when I try to start a monitor. Can
>someone tell me what the
>trouble is? TIA,
>-Jim
> <<<<x0> not running!
94550
Did you create a monitorcap file, and did your setup create the nodes for
fifo.1a etc in the correct directory? I got errors like this when I failed
to do these two things from a source install under Linux.
