GRASS 5.0 beta2 Released!
Jack Cummings
sauron at angband.ee.ualberta.ca
Tue Jul 27 13:55:11 EDT 1999
On Tue, Jul 27, 1999 at 04:51:18PM +0200, Luca Palmeri wrote:
> Some problems caused by unresolved simbols in libcurses, I was not able to
> figure out how
> to use the ./configure script in order to add the -lcurses linker option so
> I modified manually
> the file src/CMD/head as follow:
Hmm. Worked fine under glibc-2.1.2 and ncurses-4.2. ( speaking of which I like the new curses interface )
> CURSES = -lcurses $(TERMLIB) $(COMPATLIB)
> > In file included from main.c:19:
> > rom_proto.h:21: macro `strchr' used without args
> > make[1]: *** [OBJ.i586-pc-linux-gnu/main.o] Error 1
> > make[1]: Leaving directory
> `/usr/local/grass5/src/grass5.0beta/src/raster/r.out.mpeg'
> > GISGEN failure at STEP: src/raster/r.out.mpeg
> > make: *** [do-install] Error 1
> I do not know how to solve this, so I simply skipped the two programs and
> kept the old
> versions.
Just delete that line. strchr() is now a macro definition.
--Jack
April 1
This is the day upon which we are reminged of what we are on the other three
hundred and sixty-four.
-- Mark Twain, "Pudd'nhead Wilson's Calendar"
====-=-==== Jack (John) Cummings == cummings at nyquist.ee.ualberta.ca ====-=-====
========== for pgp public key --- finger the above address, and pray ==========
