A GRASS question (sorry no mailing list comments)
R. Joe Brandon rjoe at cast.uark.edu
Wed Jun 2 16:18:59 EDT 1999
While it is nice to see everyone all chatty about the mailing list I have
more down to earth questions about a problem in Grass5.0beta on my Mklinux
machine.  With Tom's excellent help (and a few key pieces from Malcolm) I
have been able to get all of Grass compiled except for a few minor moudules (I left the list at my office).
Most significant was that I had to go to /etc and do a ln -s /bin/mknod mknod
to get mknod to work correctly.  As a result of that everything seems to
be working fine including tcltkgrass but I have run into two problems.
A:  (and I really need this one to work!) in s.menu after loading up my
sites and then doing an occurrencre report on them agaist a raster map,
the calculations run but the program halts when it should be giving me
the report and tells me
Can't open report file
/usr/local/grass_data/rjoe/test/rjoe/.tmp/localhost.localdomain/4478.0 no
such file for directory.
each time I run this it gives me a different number after ...localdomain/
I have the feeling this is a permissions problem and so on a whim did a
chmod 777 on localhost.localdomain but that did not fix anything...
comments please?
B: v.digit, which I also really need to work did not compile until after I
fixed the mknod problem.  I reran GISGEN starting with v.digit in the nextstep and everything went
fine. I then ran MAKELINKS.head.  Now when I enter v.digit it says it can
not find it?
Thanks!
R. Joe Brandon
Center for Advanced Spatial Technologies           (fax) 501 575-5218
Rm. 12 Ozark Hall                                        501 575-4277
University of Arkansas                             rjoe at cast.uark.edu
Fayetteville, AR 72701
Partially restored -> http://www.cast.uark.edu/~rjoe
