Problem importing ESRI Shape files
Frank Warmerdam
warmerda at home.com
Fri May 7 12:03:29 EDT 1999
e9325495 at stud3.tuwien.ac.at wrote:
> Hi!
> I have some comercial shape files that I can't import with v.in.arc. ( I use Grass 5.0b)
> g.region responses with an error message "north must be north of south.." or something like that.
> Could it be there ist something wrong with the projection? How can I change the projection?
> The files work perfectly with ArcView 3.0.
> Anybody got a solution for this problem?
> Thanx, Werner Masik
Werner,
As I understand it v.in.arc reads arc/info generate files. If you want to
read shapefiles you might try building my v.in.shape program.
http://gdal.velocet.ca/projects/grass
Good luck,
I set the clouds in motion - turned up | Frank Warmerdam, warmerda at home.com
light and sound - activate the windows | http://members.home.com/warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
