Problem importing ESRI Shape files
    e9325495 at stud3.tuwien.ac.at
    Fri May  7 18:37:52 EDT 1999
On Fri, 07 May 1999 12:03:29 -0400, Frank Warmerdam wrote:
>e9325495 at stud3.tuwien.ac.at wrote:
>> Hi!
>> I have some comercial shape files that I can't import with v.in.arc. ( I use Grass 5.0b)
>> g.region responses with an error message "north must be north of south.." or something like that.
>> Could it be there ist something wrong with the projection? How can I change the projection?
>> The files work perfectly with ArcView 3.0.
>> Anybody got a solution for this problem?
>> Thanx, Werner Masik
>Werner,
>As I understand it v.in.arc reads arc/info generate files.  If you want to
>read shapefiles you might try building my v.in.shape program.
Sorry, I was confused. When I wrote v.in.arc I meant v.in.shape. :-) I'm running GRASS 5.0beta so it is already part of the distribution.
I'm a newbie on GIS-Systems so I have some problems with all the different coordinate systems.  I can't find out why one shape-file can be imported without
any problems and the other fails. The shape files cannot be damaged because they are comercial and work perfectly on ArcView 3.0. So I thought that the
files that don't work are in some kind of different projection. But how can ArcView know the difference? Anyway - the files that can be imported seem to be a
little distorted on the screen. Maybe this is a projection problem too.
The last thing I'd like to know: how  can  I put the import shape-vector files into a new mapset? Because the parameter [mapset=name] doesn't seem to be
enough. I read somewhere that when I create a new mapset then a new projection is created. Maybe this would be the solution.
If anybody is interested in analyzing the files I can send you some sample data.
Thanx, Werner
>  http://gdal.velocet.ca/projects/grass
>Good luck,
Thank you - I will need it!
>I set the clouds in motion - turned up | Frank Warmerdam, warmerda at home.com
>light and sound - activate the windows | http://members.home.com/warmerda
>and watch the world go round - Rush    | Geospatial Programmer for Rent
