GRASS graphics driver can't set color
James Harper
jharper at jps.net
Fri May 21 22:48:56 EDT 1999
It sounds as if you might be starting X windows as Root. Log in as another
user (not a root user) and then go into X windows and start the monitor.
For some reason X windows will not support 8bit color when logged on as
Root. I am assuming that you have already setup the monitors using via
monitorcap file and set mknod/chmod to the fifo devices. If not it is
really easy to do and if you like I will give you detailed instructions on
how to set them up.
James Harper
-----Original Message-----
From: grass at pandora.cecer.army.mil [mailto:grass at pandora.cecer.army.mil] On
Behalf Of Jaro Hofierka
Sent: Friday, May 21, 1999 11:45 AM
To: grass-list at cecer.army.mil
Subject: GRASS graphics driver can't set color
Hello,
We have problems installing GRASS4.2,4.1 on Red Hat Linux with
XFree3.3.3. Starting x0 monitor within 8 bit X windows
and using d.mon start=x0 we've got the following errors:
Graphics driver [x0] started
Color: can't set color 0
Using X windows with 16 bit or 32 bit colour depths we've got:
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 78 (X_CreateColormap)
Serial number of failed request: 270
Current serial number in output stream: 271
Do any of you have ideas how to fix it?
We appreciate any help.
With best regards,
Jaro Hofierka
