GRASS graphics driver can't set color
Jaro Hofierka
hofierka at netlab.sk
Thu May 27 15:33:26 EDT 1999
At 19:48 21.5.1999 -0700, you wrote:
>It sounds as if you might be starting X windows as Root. Log in as another
>user (not a root user) and then go into X windows and start the monitor.
>For some reason X windows will not support 8bit color when logged on as
>Root. I am assuming that you have already setup the monitors using via
>monitorcap file and set mknod/chmod to the fifo devices. If not it is
>really easy to do and if you like I will give you detailed instructions on
>how to set them up.
>James Harper
James,
You are right! Thank you and also all who replied to my request.
Regards,
Jaro
>-----Original Message-----
>From: grass at pandora.cecer.army.mil [mailto:grass at pandora.cecer.army.mil] On
>Behalf Of Jaro Hofierka
>Sent: Friday, May 21, 1999 11:45 AM
>To: grass-list at cecer.army.mil
>Subject: GRASS graphics driver can't set color
>Hello,
>We have problems installing GRASS4.2,4.1 on Red Hat Linux with
>XFree3.3.3. Starting x0 monitor within 8 bit X windows
>and using d.mon start=x0 we've got the following errors:
>Graphics driver [x0] started
>Color: can't set color 0
>Using X windows with 16 bit or 32 bit colour depths we've got:
>X Error of failed request: BadMatch (invalid parameter attributes)
> Major opcode of failed request: 78 (X_CreateColormap)
> Serial number of failed request: 270
> Current serial number in output stream: 271
>Do any of you have ideas how to fix it?
>We appreciate any help.
>With best regards,
>Jaro Hofierka
