Create GRASS database by script
Agustin Lobo
alobo at ija.csic.es
Fri May 28 12:49:37 EDT 1999
Markus,
You can use ECHO $var > file.name
to create the files (i.e., DEFAULT_WIN)
where $var contains text that you pass to the script in
the command line. For the first line you use > and
for the rest >> to append.
You can also create the directories with mkdir.
For example (this is not tested):
#!/bin/csh
#set echo
#set verbose
(uncomment for testing)
set nameLOC = $argv[1]
set nameMAPS = $argv[2]
set defWIN.proj = $argv[3]
etc
mkdir $nameLOC
cd $nameLOC
mkdir PERMANENT
cd PERMANENT
echo "proj: " $defWIN.proj > DEFAULT_WIN
echo "zone: " $defWIN.zone >> DEFAULT_WIN
and so on.
Agus
****NOTE NEW PHONE NUMBER*****
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
http://pangea.ija.csic.es/alobo
On Fri, 28 May 1999, Markus Neteler wrote:
> Hi all,
> I would like to create a new GRASS databse
> (with location definition etc.) by script.
> Is there a way to do that?
> Thank you
> Markus Neteler
> Geographisches Institut | Schneiderberg 50
> + Physische Geographie 30167 Hannover, Germany
> & Landschaftsoekologie + Tel: ++49-(0)511-762-4494 /-3924
> Universitaet Hannover Fax: ++49-(0)511-762-3984
> neteler at geog.uni-hannover.de
> http://www.geog.uni-hannover.de/users/neteler/
