projecting problems
juhana juhana.nieminen at helsinki.fi
Sat Nov 6 00:43:18 EST 1999
Hello GRASS community...
I've been trying to project data from a LAEA site with a
central meridian of 180W to a LAEA locations with a cental
meridian of 0 E (basically turning data in the"same projection
" 180 degrees".
-results-
r.proj works occationally but the depending on how the data
         has been cut it either gives the error that north must be
         greater than south or then it projects a small piece of the
         wanted area leaving the rest blank.
v.proj doesn't give any errors and everything seem ok until
         data is looked at. Then it may be noticed that the vectors
          have been turned around to the right direction but are
          somehow placed having their south edge starting from
          where the north limit is supposed to be
Similar trouble is met when the data is tried to be spooled though
a LatLong locations - where data is projected but not to the correct
geographical location.
But then there is no trouble projecting material from Latlong to either
of the above mentioned locations (laea180 anf laea0)
Any suggestions?
Is it a problem with the  projecting program or could there be a
simpler answer?
thanks in advance...
Juhana
Juhana Nieminen, Division of Environmental Biology, GIS Laboratory
P.O.Box 44 (Jyrangontie 2)              tel: +358-9-191 40059
FIN-00014 University of Helsinki        fax: +358-9-191 40048
Finland                              http://ginkgo.pc.helsinki.fi
