A stupid question...
Conn Copas
conn.copas at dsto.defence.gov.au
Mon Nov 8 21:37:09 EST 1999
"Linda Moet" <lindam at gwnsys.ca> writes:
> To help get you going, here are some random thoughts on what has to happen
> to make GRASS accessible over the Internet:
> 2) In order for a web user to access a mapset, they must own it. (There
> was a discussion on the list a short while ago about sharing mapsets and why
> it isn't possible - only the owner of a mapset can access it.)
More precisely, in order for a user to execute any Grass command, they must
possess their own mapset. This is actually an unnecessary restriction in those
cases where users simply want read-only access to some common dataset. Most d.*
and g.* commands, for example, do not write anything to the mapset, and this
tends to be the province of r.* commands. There would be some merit in
re-programming Grass so that individual mapsets are only constructed upon
demand. This would require some minor tinkering around with the gis libraries,
and would involve making Grass store the user's WIND in an alternative location
(like .grassrc). Another possible extension for the enthusiast would be to make
Grass write to the client rather than to the server.
Conn V Copas
Information Technology Division
Defence Science and Technology Organisation
PO Box 1500
Salisbury tel: +61 (0)8 825 95349
SA 5108 fax: +61 (0)8 825 95589
Australia e-mail: Conn.Copas at dsto.defence.gov.au
