ArcInfo .e00 import help (newbie)
Michel Wurtz - ENGEES/CEREG
mw at engees.u-strasbg.fr
Fri Nov 19 02:17:10 EST 1999
Rick Ree wrote:
> I have an .e00 file containing hypsography data. I imported it into GRASS
> using m.in.e00, and can display the vector map using d.vect and so on. But
> how would I (for example) color-code the contours according to elevation?
m.in.e00 creates one category file per attribute in $LOCATION/dig_cats
their name is made with the following rule : <vector_name>.<attribute_name>,
where <vector_name> is the name of your vector file, and <attribute_name>
is the name of an attribute in the Arc/Info coverage.
You have to identify which attribute contains the elevation, then
perform a v.reclass using this file as a base for the rule file.
Michel Wurtz ENGEES - CEREG
1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
