s.in.ascii
Andrew M McDermott
Andrew at psi.potsdam.edu
Mon Oct 4 08:46:01 EDT 1999
At 02:37 PM 10/4/99 +0200, you wrote:
>"C.D.Lloyd" wrote:
>> Hello Henk,
>> It sounds like you're missing a character before the z variable. I think
>> you need to add an # to all your z variables in the file you are reading
>> in with s.in.ascii. Therefore:
>> X Y Z
>> 123 342 #23
>> All should then be ok.
>This is what I thought as well. The resulting sites file then looks like
>22:30:02.484E|27:59:59.136S|0|
>s.surf.idw then says "I'm finding records that do not have floating
>point attributes"
>and stops, with the message:
>"s.surf.idw: no data points found"
use the management programs to edit the sites file and replace the
qualifier on each height i.e. make every "#" a "%" instead ( or put a "%"
in front of each height).
>Henk
