s.in.ascii
Henk Coetzee
henkc at geoscience.org.za
Mon Oct 4 09:28:52 EDT 1999
Andrew M McDermott wrote:
> At 02:37 PM 10/4/99 +0200, you wrote:
> >"C.D.Lloyd" wrote:
> >> Hello Henk,
> >> It sounds like you're missing a character before the z variable. I think
> >> you need to add an # to all your z variables in the file you are reading
> >> in with s.in.ascii. Therefore:
> >> X Y Z
> >> 123 342 #23
> >> All should then be ok.
Hi
I have done this and imported the file using grass4.2.1, which seems to
interpolate OK. Is this a problem in 5.0beta3?
Henk
Henk Coetzee
Geophysics Unit
Council for Geoscience
Private Bag X112, Pretoria, 0001, South Africa
Tel: +27-12-841-1192 Fax: +27-12-841-1424
