Different users on the same mapset
Luca Palmeri lpalmeri at ux1.unipd.it
Wed Oct 13 06:59:24 EDT 1999
Dear grass comunity,
        Yesterday for the first time since I use grass, I have been
faced with an interesting question:
        can different users work on the same mapset ?
So I tried, I played with unix privileges moved mapsets changed user
and group etc. etc. and discovered that finally THE ANSWER IS NO !!!
at lest not in grass5beta3 on alinux RH6.0 (posix compliant) platform.
Well, this is a little bit strange. Why shouldn't be possible in a
multi user environment such as unix to use the same mapset under
different usernames (maybe in the same group) ?
This could be very usefull especially for large projects whit many
people involved in.
The problem is in a GRASS GIS library call G__mapset_permissions,
that looks like:
int G__mapset_permissions (char *mapset)
    char path[256];
    struct stat info;
    G__file_name (path,"","",mapset);
    if (stat (path, &info) != 0)
            return -1;
    if (info.st_uid != getuid())
            return 0;
    if (info.st_uid != geteuid())
            return 0;
    return 1;
Simple, everytime that a call access mapsets data a check is done
for the userid of the mapsets file to be equal to that of real and
effective ids of the invoking process. So if I own a mapset I can
work on it, if I do not own it I cannot regardeless of the unix
mapsets files privileges.
I have only one question, why ? I do not understand this idea.
Ok so I went forward and changed a little bit the code. But if we
release this constraint by for example commenting the last two ifs
in the call, we will have to check for access permission to the mapsets.
This is done at start time in gis_set. I've done some work on that
and modified the gis_set and the g.access programs.
Anyhow at this stage I do not think it is a good idea to post my bugfixes,
that are to be considered much more as tournarounds. A sound understanding
of the global grass structure and clear objectives on how to manage mapset
permissions are needed in order to produce a proper code.
So here I just want to point out that THIS IS AN IMPORTANT ISSUE. Clearly
if somebody is interested in having my patch I can send it. But I would first
like to understand the developping strategy beneath the G__mapset_permissions
call.
Comments are welcome
LP
--> Luca Palmeri - Dip. Proc. Chimici dell'Ingengeria
    Universita' di Padova  TEL: +390498275527 -------
-------------------------  FAX: +390498275528 -------
--> Think holistic @ the end of the 2nd millenium <--
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/19991013/08aafd7e/attachment.html
