Different users on the same mapset
Michel Wurtz - ENGEES/CEREG
mw at engees.u-strasbg.fr
Wed Oct 13 08:29:47 EDT 1999
Luca Palmeri wrote:
> The problem is in a GRASS GIS library call G__mapset_permissions,
I've once read (in grass doc ?) that you can share a location.
Each user has its own mapset, and the PERMANENT Mapset is shared
and read-only for the non-owners (you must use xxx at PERMANENT to
access them). I don't remember if you can read other mapsets in
the same way.
I didn't test this yet...
Michel Wurtz ENGEES - CEREG
1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
