Problems with ps.map
Michael Schulz
schulzm at perm.geologie.uni-freiburg.de
Tue Oct 19 16:30:26 EDT 1999
Hi Terry!
It has been a while since I used ps.map, but I also had problems with the
grid option in a skript file. I found that it only worked when you are
drawing a rastermap, and not if you only draw vectors, and you have to
explicitly set the text atts in the grid command: Ex:
-- snip
grid 1000
numbers 1
font helvetica
fontsize 5
end
I never used the header option, but it looks like you have to provide a
special text file, not that it gets header information from a map by its own.
Hope this helps.
Michael
Michael Schulz
Christoph-Mang-Str.5 Geologisches Institut
79100 Freiburg Universitaet Freiburg
Albertstr. 23b
79104 Freiburg
On Tue, 19 Oct 1999, Terry Duell wrote:
> Good afternoon all,
> I am currently using Grass 4.2.19, with tcltkgrass, and have been trying
> to sort out how ps.map works (setting up some PostScript devices,
> learning how to write a ps.map script file etc).
> I am finding that it doesn't exactly do as I would have expected, in
> that no header, or grid coordinates etc are provided, even though the
> script asked for them or they should have been provided as a default.
> Is there any among you who have been through this and figured out how to
> bludgeon ps.map into doing what it is told :-), and if so, could you
> please enlighten me.
> Cheers,
> Terry Duell, Senior Mobility Engineer
> Army Engineering Agency
> Maribyrnong, Victoria, Australia
> ph:61-3-93195837 fax:61-3-93195830
