Grass4 d.mon problem under Debian 2.1
Markus Neteler
neteler at geog.uni-hannover.de
Wed Oct 20 21:18:19 EDT 1999
Hi Adalberto!
> The new installation is as far as I know identical to the previous one and
> with the same flaw: d.mon reffuses to cooperate...
> I think it could be a problem with Debian install but it sounds strange for
> me that Grass5 works flawlessly.
> >> When I try to open a display, for instance 'x0', the program freezes.
> When I
> >> try to interrupt with CTRL+C, I get the message:
> >> "Problem selecting x0. Will try once more"
Well, another idea could be to check if the computer has a
full network name. Although it may not be in a network you could
try to specify a domain as well to fix the problem.
Example:
grass.mydomain.br
You are shure that you have a proper locks directory?
Please recheck these instructions:
- First your machine has to get a name (mulligan, Thuille, grassmachine,
what you like) and a domain name, even if not working in a network
environment.
-> Check this:
uname -n
will output this name.
- go to grass42/locks/
- mkdir "machinename" (without quotes)
Example:
$uname -n
hgeo02.geog.uni-hannover.de or just hgeo02
So the machines name is "hgeo02".
Create the required directory:
$ cd grass42/locks
$ mkdir hgeo02 (this is still an example)
$ cd ..
$ chmod -R 1777 locks
Ready.
Hope this helps. The new install script should have done this
job, therefore check for the full domain name.
Best regards
Markus
